Make a Diabolical "Master Switch"
Intro: Make a Diabolical "Master Switch"
In order to save electricity (and be green), I have set the electric in my room so I can turn everything off using a cheapo wireless switch and extention cords. I have always thought that I could use the remote like a relay to trigger the electric with an extravagant switch (in my case a key switch).
No soldering skills required.
***Warning***
Make sure you are not connecting more to the remote switch than it is rated for.
For instance, I bought a heavy duty (3000 watt) one. Most are only rated for a light or two. Be careful.
Here is a remote like the switch I used (but lower wattage).
***Warning***
STEP 1: Materials:
You do not need much for this,
You will need a remote switch, tape, a switch of some sort (I used a key switch I got from a boating supply store), tin foil, wire, and a screw driver (depends on the remote)
STEP 2: Open the Remote
Open the remote and locate the solder points on the back that correspond to the button.
STEP 3: Short Circut It!!!!!!
Now using some tin foil, short the leads that activate the switch. Make sure you take out the battery.
STEP 4: Tap Into Its Battery.
Take out the battery, in each of the ports for the battery put wires (or tinfoil). Connect one of the wires to the battery and extend the wire from the battery. You now have your two activator leads.
STEP 5: Test It Out.
Test the leads, also make sure that they are secure.
STEP 6: Connect the Switch
Preferably put the remote up high for better range and connect the two leads to your switch.
Here you see the finished switch.
STEP 7: Plug in Main Base.
Set up your house (in my case since mine is small I use extention cords behind furnuture) to use your new switch and install base station. Congratulations, you now have a wireless relay with a switch!
STEP 8: Hurraa!
Please feel free to email me any tips, [http://mailto:instructables@kittensarefuzzy.com instructables@kittensarefuzzy.com]
14 Comments
Robot Lover 13 years ago
nosut 15 years ago
Callum Snowden 13 years ago
ooklala 14 years ago
my bedroom uses about 1000 watts when everything is powered on.
the switch i use is rated for much more than that, something like 3000 watts.
also, i use one outlet because that outlet is on it's own fuse, versus the other outlet in the room, which is shared with the bathroom and microwave (meaning it is completely unusable without bursting the fuse)
jeremiahthebullfrog 14 years ago
cantthinkof bettername 15 years ago
computerwiz_222 16 years ago
ekulmeekul 15 years ago
computerwiz_222 15 years ago
cpf 16 years ago
lemonie 17 years ago
heltones 17 years ago
trinit 17 years ago
First of all, I have no idea what you mean by 'remote switch'. Without that basic piece of information, all references to parts of the device are completely useless. Could you give at least a brand or model number, so I can figure out what device you're talking about?
Anyway, this is a great idea. I think. Perhaps better if it had pictures other than 1/2" square thumbnails , which don't count. Or if I knew what you were talking about.
Remember, folks. Your description might make perfect sense to you. But without pictures, we can't tell what the heck you're talking about. Also, generic instructions (e.g. "short the leads that activate the switch") aren't that helpful without at least a picture showing what you mean.
Summary: It should be possible to reproduce your hack--with nothing more than some common sense and the words on this page. More description please!
trinit 17 years ago
